Hello
Guest
it is
March 29, 2024, 07:00:44 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 Starting to behave erratically!
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 Starting to behave erratically! (Read 1853 times)
Dougie
3
on:
January 07, 2017, 09:07:48 AM »
HELP! We are half through our biggest job (600 sheets of 18mm ply) and Mach 3 is starting to behave erratically.
There are 2 symptoms:
1) The 2 X drive stepper motors appear to go out of sync when returning to fixture zero causing the X carriage to jerk violently and derail.
2) Intermittently, starts cutting a file too early (ie short of X destination) on the X axis all the while making bad noise??
Can anyone help this operator. This happens about every 4th sheet?
Look forward to any suggestions. Thanks.
Logged
ger21
6,295
Re: Mach3 Starting to behave erratically!
Reply #1 on:
January 07, 2017, 09:36:53 AM »
Loose wires, failing drive or motor? Carefully check both X axis motors and drives, and all wiring that they use.
Logged
Dougie
3
Reply #2 on:
January 07, 2017, 09:43:48 AM »
Thanks Gerry
The one other main issue is when tracking to fixture home, that's when the X axis plays up. So will do the checks and report back.
Thanks for your speedy response.
Logged
Highspeed1964
126
Reply #3 on:
January 09, 2017, 06:48:21 PM »
With it being such a large job, my guess would be mechanical. Parts tend to wear out, although it could also be loose wires like Gerry said. But motors and mechanical wear would be where I start after checking those wires.
Highspeed
Logged
Print
Pages:
1
Go Up
« previous
next »
