Hello Guest it is April 25, 2024, 12:02:17 AM
Author Topic: Big trouble  (Read 4268 times)
Big trouble
« on: January 06, 2017, 08:14:27 PM »
Hi all. I am new to the cnc but my limit switch keeps tripping every 10 seconds approximately.  Even though no axis is even need the limit switches. So I go to the diagnostic screen and nothing is lit up. I then go to con fig /pots&pins/input and start x ing the limits until I stop getting the limit warning. It seems to be in the y axis and I don't know why I am getting this all of a sudden for no reason. Can anyone help me I'm out of ideas.
Offline Davek0974
  •  2,606 2,606
Re: Big trouble
« Reply #1 on: January 07, 2017, 03:48:06 AM »
Usually a broken or loose wire/connection.
Re: Big trouble
« Reply #2 on: January 07, 2017, 06:40:00 AM »
Have you introduced a new piece of electrical equipment near to your machine. I had a faulty strip light that gave electrical noise that caused strange signal to the computer via the BOB. You could try increasing the de-bounce to 200 in the general config pull down menu that might help if it is electronic noise that's causing the problem.
Re: Big trouble
« Reply #3 on: January 07, 2017, 06:57:06 AM »
No I was running a gcode and a limit tripped. I was just air cutting.  My switches are nc in the diagnostic screen there is no lights lit to tell me a limit has tripped
Re: Big trouble
« Reply #4 on: January 07, 2017, 07:00:59 AM »
 If it is random noise causing it to trip sometimes the "signal" is faster than the computer screen scan time so no light will show up.
Check the Y axis wiring for broken or loose wires, especially the wire shielding connection if you are uisng it.
Mike
Re: Big trouble
« Reply #5 on: January 07, 2017, 07:03:30 AM »
Okay I will check this morning. I will let you know how I make out  thanks
Offline Davek0974
  •  2,606 2,606
Re: Big trouble
« Reply #6 on: January 07, 2017, 08:20:12 AM »
NC circuits are not usually prone to noise as there is a constant signal there - this is one of the good points of them over NO circuits.
I would engage the system, then start gently moving and wiggling the cables between the head and the control box, no need to go nuts, just a gentle wiggle, and see if you can make it trip.
Re: Big trouble
« Reply #7 on: January 07, 2017, 08:59:08 AM »
I can't it trips without moving
Re: Big trouble
« Reply #8 on: January 07, 2017, 09:02:15 AM »
I wonder if my shield ground came off at the bob for the axis I am having trouble with
Re: Big trouble
« Reply #9 on: January 07, 2017, 09:42:27 AM »
I closed mach and reopened it. Everything seems to be working fine now. I checked the wires no problems. I don't know why I got the glitch but it okay now. Any ideas.
