Hello Guest it is April 25, 2024, 01:29:05 AM
Author Topic: DRO Function  (Read 2427 times)
DRO Function
« on: January 05, 2017, 03:28:17 AM »
Hi there
I realise there are different ways to get DRO value, for example, to get the current tools number, we can use oldTool = GetOEMDRO(1200) or oldTool = GetDRO(24), which one is better?
Does someone have a new list of DRO,LED, Button? I found information from Mach3Wiki, but last change was in July 2010. I am afraid there are some information missing.
Thanks, Jun
Re: DRO Function
« Reply #1 on: January 05, 2017, 07:28:25 AM »
GetOEMDRO is the newer version, but it doesn't really matter which one you use.
If you search through the forum here, you can probably fins a more updated list, but the Wiki should have about 99% of the codes.
Re: DRO Function
« Reply #2 on: January 05, 2017, 09:11:37 AM »
Thanks Gerry, on the Wiki OEMDRO is up to number 836, but it works also with 1200, I don't know where i can find the definition/function of such OEMDRO.
