Trying to get the "Macro-2" and "Macro-3" buttons on my LHB04 pendant to "Set Home X" & "Set Home Z"individually in the stock Mach3 Turn screen. Thanks to Rich, I was able to get the Spindle CCW command to work using the Config plug-in screen in Mach...entered the button code 173 in the Macro number1 box on the bottom & selected Spindle CCW toggle from the drop-down in the upper Macro-1 box. Cool, press the Macro-1 button on the pendant & away it goes spinning backward. That alone was worth the money...almost.
I tried the available options for homing the X & Z individually using the plug-n drop down menu options but nothing works except homing both at the same time. Not good for my setup. Remembering what Hood had told me earlier about "DoOemButton(1024, I tried to get that to work to home Z using the various custom options that are in the confusing Chinglish manual but so far no luck. Anybody have any suggestions? Manual .pdf attached
