Hello Guest it is March 28, 2024, 12:56:30 PM
Author Topic: Maximum size?  (Read 9030 times)
Maximum size?
« on: December 29, 2016, 02:10:47 PM »
I am looking to use Lazy Turn to turn a piece that is 48" long in wood. I am having a terrible time getting the dxf's into Lazy Turn, have I exceeded some unwritten limit?
Re: Maximum size?
« Reply #1 on: December 29, 2016, 03:14:03 PM »
Not that I know of.
If you read the manual you will see information on dxf files and how the drawings should be created.
Post your dxf file.
Re: Maximum size?
« Reply #2 on: December 29, 2016, 04:21:07 PM »
This is the dxf I am wanting to use. It was created in AutoCad and saved as v12 dxf. I am still learning how to create this in the middle of my stock.
Re: Maximum size?
« Reply #3 on: December 29, 2016, 04:23:46 PM »
I believe I followed all of the rules for drawing creation.
Re: Maximum size?
« Reply #4 on: December 29, 2016, 06:33:54 PM »
Try the attached dxf file.
I attached some pathing screen shots from the attached dxf.
Re: Maximum size?
« Reply #5 on: December 29, 2016, 07:35:15 PM »
What magic did you use so I can duplicate the process?
Re: Maximum size?
« Reply #6 on: December 29, 2016, 10:40:31 PM »
No magic at all.
1. I saved your dxf and converted it to 2007 ACAD which I use.
    The image was mirrored about the vertical.
    Then added a radius .002" at all the sharp points pointing inward to the stock.
    Next I saved the file as a version 12 dxf.
2. One needs to be practical when creating a profile such that a tool can actually cut the profile.
    ie; The reason for the 0.002" radius was so that a 0.001" wide tool could cut it, but practically speaking, no such a tool exists!
3. Then I just did a roughing and a finish pathing.
4. To quickly see the pathing you just use the scan line diagnostics. Else if you don't you may need to waite quite long as there is a lot
    of tool paths being created depending on settings for the profile cut. If the pathing suites your needs then create a profile paths.
5. Please read the manual, don't hack the program. It's  all in the manual and that is why I wrote the thing.
I like when mommy reads to me at bedtime, I can't since I can only write!  ::)
RICH  ;)
« Last Edit: December 29, 2016, 10:45:29 PM by RICH »
Re: Maximum size?
« Reply #7 on: December 30, 2016, 05:38:08 AM »
See Appendix B in the manual and note the following drafting errors:
3.5 and 5.10.
I forgot to list in item 1.0 in reply #6 that the polyline was exploded.
Re: Maximum size?
« Reply #8 on: December 30, 2016, 10:35:42 AM »
Thank you for your wisdom. I use the autocad join to insure no gaps in the drawing, just didn't realize a zero width polyline is still a polyline. Back in the manual, I understand the right and left cut direction. I believe in order to make the cuts bi-directional the toolpaths need to be interlaced, the simulation runs one toolpath before running the second which I believe defeats the intended use.
Re: Maximum size?
« Reply #9 on: December 30, 2016, 01:18:41 PM »
All I can say that LT is what it is and will not be enhanced or updated.
BUT.....as a FREE program for the lathe used within what it was intended to accomplish.........it serves the needs of many.
