Hello Guest it is April 23, 2024, 10:56:03 AM
Author Topic: Motors set up tab  (Read 1511 times)
Motors set up tab
« on: December 25, 2016, 04:30:07 PM »
I set up my mill with smoothstepper latest plug is (188) and mach4 (2.0.3233).
I have set all the inputs and outputs in the plug in and in mach4. The spindle runs and I can control the speed, I can move all the axis using the jog buttons on the screen.
However when I go to the motors tab to set the speed/acceleration/deceleration and steps per unit all the boxes are greyed out, I cannot enter any values.
Is this because I have not yet purchased a licence? demo mode
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Motors set up tab
« Reply #1 on: December 25, 2016, 05:46:06 PM »
The motor boxes normaly are greyed out until you select a motor.
DazTheGas
« Reply #2 on: December 28, 2016, 06:05:20 PM »
Disable Mach4 then go to motor page then move mouse to motor0 then click and you will see parameter and will be able to make changes.
