Hello Guest it is April 25, 2024, 02:56:42 PM
Author Topic: New Screenset for Mach3 Turn is here!  (Read 61534 times)
Offline DaBase
  •  36 36
  • Metalhead
« on: December 19, 2016, 09:17:12 AM »
We are glad to announce the new Ease-eTurn for Lathe Screenset!
This thing turns your Mach3 Turn into completely user friendly product!
Features:
16:9 ratio adjusted Screenset! Enough with the old-fashioned 1024x768!
Large toolpath window
Files included for CSMIO-IP/S by CS-Lab
Completely rebuilt wizards in Conversational tab, including Quick Threads by Poppabear in new look!
Settable safe Toolchange Position with one click button and safety, saving time on long and unneeded travels, also usable with M code
Lubrication alarm for users with Auto lubrication system
Machine operated (air or hydraulic) collet chuck or jaw chuck opening/closing by one click button, also usable with M code, with displaying current status LED
Distance To Go for visual reference to avoid any crash
Current Work Offset (G54, G55, G56 etc.) appearance on display
Feed override slider
Spindle override slider
Spindle load monitoring in two ways:
* By reading from VFD analog output (0-10V)
* By comparing True and Set RPM
Spindle Stall detection with LED
Optional Hydraulics/Air compressor On/Off switch
Feed per Rev setting by one click button
Constant Surface Speed (CSS) setting by one click button
Easy to use separate Offsets window for setting Tool and Work offsets
Separate window for all coordinate systems (Machine, Axis, Work)
M01 Break (Optional Stop) button with LED
Included Macro for rotational or linear Automatic Tool Change with logics to go shortest distance, easy to configure for 4-bit encoder or using switches
User friendly safety logics preventing against crash
* Collet Open/Close preventing Spindle Start, Cycle Start
* Protection against wrong tool (for example, Tool 0 instead of 1) by warning user with pop-up window
* Preventing Cycle Start before homing all axis after Reset
* Waiting for Spindle while it spins up to commanded RPM, then allows program to continue
Conversational part features:
Easy-to-use wizards
Usable in both - radius and diameter mode
Option to append multiple wizards in one usable G-code file
Brain included:
Brain for Collet Signal On/Off (for one pin)
Brain for controling Hydraulics (settable Output pin) button on screenset
Brain for external Pause and Stop buttons
Brain for Spindle Stall Detection (must use RPM counter on Spindle)
Brain for Spindle Load meter, if no Analog Input from VFD (comparing True RPM and Commanded RPM)
Brain for Chuck opening/closing safety, so when Spindle is turning, it is impossible to open it
Brain for Lubrication alarm (no oil)
Currently Screenset is made for Metric users, in few days Imperial version will be ready.
Install instructions are on YouTube: https://www.youtube.com/watch?v=emUI7DDnI6k
Price for the Screenset is 25 Eur via PayPal, please write me PM about buying it.
We <3 to Code();
Offline DaBase
  •  36 36
  • Metalhead
Re: New Screenset for Mach3 Turn is here!
« Reply #1 on: January 04, 2017, 06:03:29 AM »
Modified "Quick Threads" from G76 to G32 cycles with working threading for lathes.
G76 did not worked because of rapid infeed at crazy rates, for example, in metric threads at 1000RPM and pitch 1.5mm machine started operating at F1.5/rev ignoring Mach3 Motor Tuning settings and tried to do rapid feed on very small distances at 1500mm/min momentary which causes missing steps for steppers and PID error for Servo systems.
Everything is tested and works with included Threading wizard.
We <3 to Code();
« Reply #2 on: January 30, 2017, 01:00:28 AM »
How do I get this new screenset.
Offline DaBase
  •  36 36
  • Metalhead
« Reply #3 on: February 01, 2017, 03:59:15 AM »
You can contact me on PM and buy it through PayPal. Then I will send it to you.
We <3 to Code();
« Reply #4 on: February 01, 2017, 08:29:12 AM »
Is the Imperial version ready?
Offline DaBase
  •  36 36
  • Metalhead
« Reply #5 on: February 08, 2017, 03:39:38 AM »
Yes, it is already being sold :)
We <3 to Code();
« Reply #6 on: May 04, 2017, 12:37:50 AM »
I'd like to get your screen set, I pm'd you last week
« Reply #7 on: May 19, 2017, 05:15:09 PM »
Hello, how much, Ease-reTurn Mach3 Turn Screenset, HOW I BUY IT
Offline DaBase
  •  36 36
  • Metalhead
« Reply #8 on: May 19, 2017, 07:49:39 PM »
You have to write me PM. ;D
We <3 to Code();
« Reply #9 on: May 20, 2017, 06:52:41 PM »
OK, PAYMENT MADE, GREETINGS
