Hello Guest it is April 24, 2024, 06:07:14 AM
Author Topic: Mach 4 Bug showing in M6 Script  (Read 4841 times)
Re: Mach 4 Bug showing in M6 Script
« Reply #10 on: May 05, 2017, 05:54:59 AM »
Check the setting in Mach config tools it should tool on t6 line is tool in use not the default
Configure->Mach->Tools->Tool Change Type->T on M6 line is tool to use, is already set.
By the way, what are the concret differences between the functions "T on M6 line is next tool" and "T on M6 line is tool to use". The test of both functions didn't solve the problem.
Greetings Jannis
Offline smurph
  •  1,546 1,546
« Reply #11 on: May 07, 2017, 05:05:19 PM »
The difference is for machines that can pre-stage tools.
"T on M6 line is next tool":
T1 (Tool changer stages T1)
M6 T2 (Load T1 into the spindle and stage T2)
M6 T5 (Load T1 into the spindle and stage T5)
"T on M6 line is tool to use":
T1
M6
or
M6 T1
