Hello Guest it is March 29, 2024, 06:18:20 AM
Author Topic: XMode - Diameter to Radius - without going thru configuration  (Read 1793 times)
« on: December 11, 2016, 10:20:46 AM »
Would like to change the XMode in lathe from or to Radius or Diameter via button script without going into configuration> Turn Options.
Is it possible?
Re: XMode - Diameter to Radius - without going thru configuration
« Reply #1 on: December 12, 2016, 08:06:27 AM »
Thought someone might have an undocumented word parameter for setting the XMode in Mach3 .
Diameter parameter can be 0 ( Radius)  or 1 (Diameter), BUT, I couldn't come up with  scripting  to change the parameter value.
SO
Is it possible to do?  Don't think so!
