Hello Guest it is April 23, 2024, 12:44:26 PM
Author Topic: NEED HELP with G code for Canned Cycle??  (Read 1747 times)
« on: December 04, 2016, 02:33:11 PM »
 Write a main program and a subprogram for the following machining operation and turn in: a. First, drill 9 holes with tool# l and .257" drill on an Aluminum box tube, the Z-direction depth of the holes are .3 inches. Use right top corner as the program reference zero (PRZ). b. Then create 5/16 -18 NC threads using a tap as tool# 2 on those drill holes, the Z depth of the tapping is .6 inches.
The image is attached
« Last Edit: December 04, 2016, 02:40:34 PM by chriscmac23 »
Re: NEED HELP with G code for Canned Cycle??
« Reply #1 on: December 04, 2016, 03:03:18 PM »
Why do you want someone else to do your homework?
Should have paid attention in class!
