Hello Guest it is April 19, 2024, 02:50:24 AM
Author Topic: Installation of Mach3Version D1.90.038 not quite complete  (Read 8973 times)
« on: December 02, 2016, 12:36:30 AM »
I have installed Mach3 vD1.90.038 on an HP m7330n running Windows 7 Pro 32-bit, but according to the instructions manual I noticed a couple of steps that was missing.
1. The Setup Finished window didn't have the "Load Mach3 Driver" checkbox, only "Install English Wizards" checkbox was listed.
2. After clicking [Finish] button for setup I did not get the popup message, "Master License File found and copied to Folder".
3. I did not get the popup message, "Mach3 driver is now installed. You should Re-Boot before running program again.
After rebooting PC and running progam (MACH 3 MILL), I get a popup message, "Error Starting after prep".  Moving the arrows on keyboard doesn't control X,Y,Z axis; data on Mach3 is changing though.  I've confirm setup of the pin in Mach 3.
Any help would be greatly appreciated!
Carl
Re: Installation of Mach3Version D1.90.038 not quite complete - RESOLVED
« Reply #1 on: February 28, 2017, 07:05:35 PM »
Resolved my issue; uninstalled version D1.90.038 and replaced it with 3.043.066!
works like a champ!
« Last Edit: February 28, 2017, 07:08:19 PM by cabtug »
