FWIW,
Here is the macro that a friend uses. I think it is run every time the torch is moved to the next cutting operation.
Takes care of warpage on thin material.
I am a complete dumb dumb about plasma.
Oh, BTW, Lazycam can be used for plasma...."if" I remember correctly you use the Mill modul for pathing, but use the Plasma to generate the code. He uses it all the time and works fine.
Call SetOEMDRO(802, 0) 'Set Z DRO = 0.00
Code "G31 Z-8.0 F60" 'probe surface
While IsMoving()
Wend
Code "G4 P.5" 'wait
ZprobePos = GetVar(2002) 'get contact point
Code "G0 Z" &ZprobePos 'return to point to remove overshoot
While IsMoving()
Wend
While IsMoving()
Wend
Code "G4 P.5" 'wait
Code "G0 Z.480 F30" 'remove floating head travel
While IsMoving()
Wend
Code "G4 P.0" 'wait
Call SetOEMDRO(802,.100) 'Set Z DRO = 0.00
While IsMoving()
Wend
ActivateSignal(Output2)
Again, FWIW,
