Hello Guest it is April 25, 2024, 08:20:02 PM
Author Topic: Mach4 ESS not responding  (Read 6430 times)
« on: November 25, 2016, 05:12:42 PM »
At first all seemed good with Mach4 motor setup but it would not see the motor for tuning.  Then I rebooted and the ESS IP address changed to 10.9.9.2 and will not allow 10.9.9.9 even with the utility and jumper.  Mach will not run now.  I plan to format the drive and start over without Norton or wireless internet then add Norton and wireless through USB once Mach is set up.  Does that make sense? Or would Norton or wireless not be the problem?
Keith
Re: Mach4 ESS not responding
« Reply #1 on: November 25, 2016, 05:36:21 PM »
Confused between 10.9.9.9 and 10.9.9.2 addresses.
« Reply #2 on: November 25, 2016, 10:12:54 PM »
There is also an error that says there are 2 computers on the network with the same IP address and I could not resolve that problem either.  Is there a way to uninstall Mach4 and ESS so they can then be reinstalled?  When I go to uninstall Mach4 is not on the list--strange... ???
« Reply #3 on: November 25, 2016, 11:42:26 PM »
All fixed and wow! Is ESS and Mach4 a big improvement over Mach3.  The same motor and lead screw is about 3 times faster with no stalls! So happy I switched!
Problems from earlier post solved by uninstalling from the uninstall module in the Mach4hobby directory then reinstalled everything in about 3 minutes.  I had done it so many times with failure that it was a great eureka moment when that stepper motor started to scream across the table!
  •  9,199 9,199
« Reply #4 on: November 26, 2016, 01:56:37 AM »
Excellent result.
