Hello Guest it is March 28, 2024, 06:42:40 AM
Author Topic: New cnc machine running but....  (Read 9902 times)
« on: November 09, 2016, 06:18:25 AM »
HEY!  Having a problem tuning my new diy woodworking cnc. I am making a clock just to test out the machine i have made the clock my previous machine so i know what it should look like.
When the machine goes around the outside of the clock to cut it out and make other circular shapes the x motors do a large clunk when the drop down to 0 rpm and then turn the other direction.
I am using:
Mach 3
chinese tb6560
nema 23 steppers
board set at 1/8 chip setting
sorry i am still learning all of the cnc stuff
Here i have a link to describe the problem also my mach settings are at the end of the video.
https://www.youtube.com/watch?v=0OyRO91hfTk
Thanks for any help/advice!
wes
Offline Davek0974
  •  2,606 2,606
Re: New cnc machine running but....
« Reply #1 on: November 09, 2016, 07:35:50 AM »
Not surfier its the problem or just a symptom but it sounds like the acceleration is set really really low - it takes a very long time to slow and speed up.
Could be resonance in the motor maybe?
Sure someone will be along to help out.
« Reply #2 on: November 10, 2016, 10:25:18 AM »
I agree with Dave, I think you could go on to YouTube and look at how to setup Mach3
Here is a place to start, you should "do" all of them, about 4 I think
regards Ford
« Reply #3 on: November 11, 2016, 06:31:07 AM »
I have watched the setup videos to no avail. i have spent hours trying to get the motors to work as smoothly as possible do you think the voltage could be a problem? i am running 4 motors off of only 12v ... the board i have says its good for 12-36, i have no other ideas,,, this is not my first build so i have been through the process before and have had a very smooth running cnc the only diffrence in my new one is its bigger and is 4 axis running 4 motors instead of my old 3 axis running 3.
Thanks for that advice i will continue to investigate
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: November 11, 2016, 06:32:38 AM »
I would certainly look at stepping up to 24v, 12 is way too low i think.
« Reply #5 on: November 11, 2016, 06:37:52 AM »
will stepping up to 24 v change any characteristic of the motors ? such as speed? temperature? steps per inch ?
Offline Davek0974
  •  2,606 2,606
« Reply #6 on: November 11, 2016, 06:58:44 AM »
It should increase the capacity to change speed better, they can reach speed faster if settings allow it, they will get a little warmer only if current is changed as well - this needs to be set at motor limit not over, steps per will NOT change - this is a hardware setting.
« Reply #7 on: November 11, 2016, 08:19:51 AM »
I used a 40 volt transformer and cranked it down to 36, the more volts you use the more watts and the more watts will give more HP.
I also asked the supplied of my card which microstep settings to use so I used that setting.
I think they are all different on different cards so please check that as you say "board set at 1/8 chip setting" sounds to me worth checking as I dont know what that means.
regards Ford
Offline Davek0974
  •  2,606 2,606
« Reply #8 on: November 11, 2016, 08:24:13 AM »
Word of caution on using the 36v supply on a 36v driver - it will have no or little headroom for over voltage caused by back emf when slowing down.
  •  9,196 9,196
« Reply #9 on: November 11, 2016, 08:32:17 AM »
How did you 'crank down' a 40 volt transformer to 36 volts ??
