Hello Guest it is April 25, 2024, 09:31:22 AM
Author Topic: Denford Mirac ATC mach3 help  (Read 1839 times)
« on: November 07, 2016, 03:53:00 PM »
I am doing a conversion on a Mirac lathe to Mach3.
i have come to the difficult bit now, i am looking some help with a macro for a tool change. on the rear of the tool changer there is a rotary switch with 8 positions and another micro switch to tell the machine it has locked.
i have all the inputs reading on the motion controller.
when the motor goes fwd it pushes the tool plate out and then starts to rotate it, on reverse it draws the plate back in until the micro switch sees it. The turret is connected to a VFD
should add i have no clue about macros.
cheers
Re: Denford Mirac ATC mach3 help
« Reply #1 on: November 08, 2016, 07:06:26 PM »
Any help at all peeps, I am totally out of my depth here.
