Hello Guest it is April 18, 2024, 07:55:57 AM
Author Topic: Pokeys57CNC Driver Connection  (Read 6542 times)
Offline Blaat
  •  10 10
« on: October 30, 2016, 03:05:10 PM »
Hi all
I'm trying to get my steppers running
This is what I did
I have a Pokeys57CNC board
steppers with 4 wires
DM542A drivers from Longsmotor
I can see my Pokeys board in Mach3.
But the steppers are not running yet.
I think I did something wrong with the wiring from pokeys to driver
Pul + (+5V) to the Pokeys 5V motor connector
Pul - to STEP pin on the Pokeys motor connector
Dir + (+5V) to the Pokeys 5V motor connector
Dir - to DIR pin on Pokeys motor connector
I didn't connect the ENBL pins
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys57CNC Driver Connection
« Reply #1 on: October 30, 2016, 03:54:51 PM »
I would strongly suggest to wire PUL+ and DIR+ to step and dir pins on the motor connector and PUL-/DIR- to GND on the motor connector.
Is motor hard (or impossible) to turn by hand?
Offline Blaat
  •  10 10
« Reply #2 on: October 30, 2016, 05:46:16 PM »
Thanks! It runs!
Mach would throw a 'emergency button error', but I had to revert the stop settings in the pokeys configuration.
Only 'problem' now is that the stepper turns, but it turns only to one side, doesn't matter if I press the < or > arrow on the keyboard.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: October 31, 2016, 12:55:00 AM »
Check the DIR+ and DIR- connections.
Offline Blaat
  •  10 10
« Reply #4 on: October 31, 2016, 03:40:05 AM »
DIR+ (driver) is connected to DIR pin (motor connector)
DIR- (driver) is connected to GND pin (motor connector). DIR- and PULL- are connected with the same cable to ground on the Pokeys Motor Connector
Offline Blaat
  •  10 10
« Reply #5 on: October 31, 2016, 08:09:08 AM »
found it, made a wiring fault from driver to pokeys.
working fine now :)
