Hello Guest it is April 26, 2024, 12:41:59 PM
Author Topic: Bentley logo G codes help  (Read 13433 times)
Re: Bentley logo G codes help
« Reply #10 on: November 15, 2016, 08:23:45 AM »
See if you can open your .dxf in AutoCad then save it as a different version .dxf
i did new one on CamBam but the parts are not joined together , i tried to do join with tolerance 0.001 but still it wont join at one piece
Can you help me with that
  •  9,200 9,200
« Reply #11 on: November 15, 2016, 10:11:53 AM »
Sorry but I do not use CamBam.
« Reply #12 on: November 15, 2016, 12:17:10 PM »
tothemaking,
I would suggest you go to the Autodesk site and download the drawing viewer which ill provide for converting
from different versions of AutoCAD to earlier versions. Also save the drawing as version 12 dxf  for use by other programs such as Cambam.
Also be carefull how you create the drawing since you need to allow for the size tool you will be using. I use arc's as that will minimize the size of the drawing and not have a zillion points to deal with.
