Hello Guest it is April 20, 2024, 10:06:18 AM
Author Topic: MachScreen LED Problem (Image Resize + OEM Code)  (Read 4966 times)
« on: October 21, 2016, 12:35:33 PM »
Hello,
I'm currently building a new screen and I stumbled upon a problem that I, for the love of god, can't get rid off. I tried for 3 hours and so here I am ;)
Basically, I want to display a LED next to the menu item (Programm, MDI, Settings..) depending on which site is currently active. Does anyone has the OEM code number for that? I tried index/826 but all LEDs are on.
But the real problem is that I can't load a custom LED image (png). It get's resized everytime. It's like the program crops a part of it and when I enter the correct size in the fields the cropped image is resized but of course therefore not correctly.
Any help is HIGHLY appreciated!!
Cheers,
Hancock
Re: MachScreen LED Problem (Image Resize + OEM Code)
« Reply #1 on: October 21, 2016, 03:06:15 PM »
Does your image have both on and off states, side by side? Only half of the image is displayed.
Like this:
« Reply #2 on: October 21, 2016, 05:02:10 PM »
Like this:
T H A N K S!!! Now the image is shown correctly sized. Now I have to figure out why it's not switching ;)
BTW: Do you happen to know if there's a manual for MachScreen? I want to customize different fonts and colors...
« Reply #3 on: October 21, 2016, 06:52:44 PM »
No, I don't know, as I use Screen4.
You can't use multiple fonts in a Mach3 screen. You only get to choose one, and it's done in Mach3.
« Reply #4 on: October 24, 2016, 11:38:20 AM »
Hi Hancock,
if you want a control be displayed on every page the best way is to put it on screen 0.
Klaus
The brain isn't a soap, it doesn't shrink when used.
