Hello Guest it is April 25, 2024, 05:45:17 PM
Author Topic: Spindle speed override problem  (Read 2269 times)
« on: October 19, 2016, 11:56:54 AM »
I'm trying to use the spindle override to increase the spindle speed to a higher value to optimise the cutting speed on my Denford Nova milling machine.
 As soon as I increase the percentage, the spindle rotates at full wack. i have to then stop the programme running and restart the spindle at the correct speed using an MDI M3 command, before starting the programme running again.
 i'm not to knowledgeable with the deeper workings of computers, so if anybody is willing to offer advice, could you please keep it simple.
 The machine i'm using has "Gecko" drivers, and is linked to the PC by Ethernet cable, rather than a serial connection.
  Thanks in advance.
    Garry
Re: Spindle speed override problem
« Reply #1 on: August 31, 2017, 11:55:37 AM »
What about using the "S" command in the MDI field, S10000 should set the spindle to 10000rpm, S12000 to 12000rpm
