February 21, 2018, 06:04:56 AM
Search:     Advanced search
+  Machsupport Forum
|-+  General CNC Chat
| |-+  Building or Buying a Wood routing table.. Beginnners guide..
| | |-+  Wiring of yoocnc 450 Kjb parallel port card to newforever inverter for Mach3 co
Pages: 1   Go Down
Print
Author Topic: Wiring of yoocnc 450 Kjb parallel port card to newforever inverter for Mach3 co  (Read 7969 times)
Shelly
Holding
Offline Offline
View Profile
« on: October 11, 2016, 01:18:37 AM »
Hi, hopping someone has done this. I have a yoocnc parrellel port card on 6040 machine and want to wire this in to run  newforever inverter
Using Mach3. There are 3 pins on the board, but don' t know whether these are opts isolated ? The can be configured to apply 0-10v signal to the inverter. any advise appreciated.  Smiley
reuelt
Active Member
Offline Offline
View Profile
« Reply #1 on: July 06, 2017, 02:49:56 AM »
The  450 Kjb parallel port card has only a PWM pin 17.
The Nowforever need Analogue 0-10V.
So your need a converter like
http://www.dx.com/p/maitech-pwm-turn-0-10v-digital-to-analog-module-green-318473?tc=AUD&gclid=EAIaIQobChMIidH98ZL01AIVkQQqCh0AsA4xEAQYAyABEgLK4fD_BwE#.WV3o2cAy_cs
Once you have Analogue 0-10V, you connect Analogue ground and  0-10V to aGND and AN1 respectively.  lower connection 1 and 3 from left on the Inverter.
You also need a pin that enables the PWM pin (probably Pin 1?) + digital ground. Top row  connection 1 and 5
Only 4 wires.
At inverter console change
P0000 set to 1
P0002 set to 2
PWM pin 17 must be  set to active low in Mach 3 otherwise you will have 10V (full speed) all the time.
PS: it might be cheaper to just change your BOB to a 5 axis BOB that includes Analogue 0-10V plus relay. Cost about $10
« Last Edit: July 06, 2017, 03:05:00 AM by reuelt » Logged
reuelt
Active Member
Offline Offline
View Profile
« Reply #2 on: July 06, 2017, 03:07:23 AM »
manual of a cheap 5 axis BOB with opto-isolation + 0-10V and a relay
www.hobbytronics.co.za/Content/external/473/5-axis%20manual.pdf
Nowforever VFD Manual: http://docdro.id/NYibeDM
« Last Edit: July 06, 2017, 03:09:00 AM by reuelt » Logged
Tweakie.CNC
CNC is only limited by our imagination.
Global Moderator
Online Online
Super Kitty
View Profile WWW
« Reply #3 on: July 06, 2017, 03:32:10 AM »
Here is another link for the E100 VFD manual:
http://ri.search.yahoo.com/_ylt=A0LEVxHE9F1Zd0UAiQlXNyoA;_ylu=X3oDMTByZnU4cmNpBGNvbG8DYmYxBHBvcwM5BHZ0aWQDBHNlYwNzcg--/RV=2/RE=1499358532/RO=10/RU=http%3a%2f%2fblog.opilab.ch%2fcnc%2fNOWFOREVER%2520MANUAL%2520E-100.pdf/RK=0/RS=MhJEQwYF4wnkaxEL9_cCyiMyl3Y-
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.20 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
