Hello Guest it is April 26, 2024, 04:04:35 PM
Author Topic: Wiring of yoocnc 450 Kjb parallel port card to newforever inverter for Mach3 co  (Read 13102 times)
Hi, hopping someone has done this. I have a yoocnc parrellel port card on 6040 machine and want to wire this in to run  newforever inverter
Using Mach3. There are 3 pins on the board, but don' t know whether these are opts isolated ? The can be configured to apply 0-10v signal to the inverter. any advise appreciated.  :)
Offline reuelt
  •  520 520
The  450 Kjb parallel port card has only a PWM pin 17.
The Nowforever need Analogue 0-10V.
So your need a converter like
http://www.dx.com/p/maitech-pwm-turn-0-10v-digital-to-analog-module-green-318473?tc=AUD&gclid=EAIaIQobChMIidH98ZL01AIVkQQqCh0AsA4xEAQYAyABEgLK4fD_BwE#.WV3o2cAy_cs
Once you have Analogue 0-10V, you connect Analogue ground and  0-10V to aGND and AN1 respectively.  lower connection 1 and 3 from left on the Inverter.
You also need a pin that enables the PWM pin (probably Pin 1?) + digital ground. Top row  connection 1 and 5
Only 4 wires.
At inverter console change
P0000 set to 1
P0002 set to 2
PWM pin 17 must be  set to active low in Mach 3 otherwise you will have 10V (full speed) all the time.
PS: it might be cheaper to just change your BOB to a 5 axis BOB that includes Analogue 0-10V plus relay. Cost about $10
« Last Edit: July 06, 2017, 04:05:00 AM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
Offline reuelt
  •  520 520
manual of a cheap 5 axis BOB with opto-isolation + 0-10V and a relay
www.hobbytronics.co.za/Content/external/473/5-axis%20manual.pdf
Nowforever VFD Manual: http://docdro.id/NYibeDM
« Last Edit: July 06, 2017, 04:09:00 AM by reuelt »
