Hello Guest it is April 25, 2024, 06:05:35 AM
Author Topic: Export DRO values (again)  (Read 2262 times)
« on: September 29, 2016, 04:39:25 PM »
Hello all,
I have read through the post in regards to exporting the DRO values and I cant seem to make it work all that well. so I hope maybe I can get some assistance with VB. here is exactly what I need to end up with... I need to export the X,Y,Z part coords and the line number DRO. I also need a system time stamp in milliseconds for each value. The XYZ and Line values can be on a single stamp.
This will run in the macro pump so I will need to add a on/off button to only activate the recording when I need it. I know how to add buttons and leds to my screenset. I just have no experience with VB.
If I could export the information to excel that would be the cats meow!
Thanks in advance for any help! Dave T.
Re: Export DRO values (again)
« Reply #1 on: October 01, 2016, 11:22:13 AM »
This is the macro that I am trying to use. It works as an Mcode but not as a macro pump. any ideas?
Private Type SYSTEMTIME
Year As Integer
Month As Integer
Day As Integer
Hour As Integer
Minute As Integer
Second As Integer
Milliseconds As Integer
End Type
Private Declare Sub GetSystemTime Lib "kernel32" (lpSystemTime As SYSTEMTIME)
Public Function GetMySecond() As String
Dim tSystem As SYSTEMTIME
Dim sRet
GetSystemTime tSystem
sRet = Format(tSystem.second, "0000")
GetMySecond = sRet
Open "c:\TESTFILE.txt" For Output As #1 ' Open to write file.
 oldX = GetOEMDRO (800)
 oldY = GetOEMDRO (801)
 oldZ = GetOEMDRO (802)
 oldL = GetOEMDRO (816)
 Write #1, oldX , oldY, oldZ, oldl
   While GetoemLED (999)
     newx = GetOEMDRO (800)
     newy = GetOEMDRO (801)
     newz = GetOEMDRO (802)
     newl = GetOEMDRO (816)
 If oldX <> newX Or oldY <> newY Or oldZ <> newZ Or oldl <> newl Then
  oldX = newX
  oldY = newY
  oldZ = newZ
  oldl = newl
  Write #1,"X",oldX ,   "Y",oldY,   "Z", oldZ,   "Line",oldl
     End If
Wend
Close #1
END Function
