Hello Guest it is November 22, 2026, 09:40:58 AM
Author Topic: Mach4 and modbus - help needed  (Read 23741 times)
« on: September 21, 2016, 04:15:51 AM »
please, can you help me with actual problem? While I can read (0x03) and write (0x06) holding register and I can read (0x01) coil, I cannot write coil (0x05). This is the code, a snippet from signal library definition, with some debug output:
Code: [Select]
[mc.OSIG_RUNNING_GCODE] = function( state )
    local hregTestCoil, rc = mc.mcRegGetHandle( inst, "modbus0/testCoil" );   -- THIS COMMAND IS FAILING
    mc.mcCntlSetLastError( inst, "testCoil handle: " .. tostring( hregTestCoil ) .. ", rc: " .. tostring( rc ) );
    local hregTestRegister, rc = mc.mcRegGetHandle( inst, "modbus0/testRegister" );
    mc.mcCntlSetLastError( inst, "testRegister handle: " .. tostring( hregTestRegister ) .. ", rc: " .. tostring( rc ) );
    if( state == 1) then
        mc.mcCntlSetLastError( inst, "signal changed to 1" );
        mc.mcRegSetValue( hregTestCoil, 1 );
        mc.mcRegSetValue( hregTestRegister, 101 );
    else
        mc.mcCntlSetLastError( inst, "signal changed to 0" );
        mc.mcRegSetValue( hregTestCoil, 0 );
        mc.mcRegSetValue( hregTestRegister, 100 );
    end
end,
Attempt to get handle for testCoil fails with return code of -27 which should mean MERROR_REG_NOT_FOUND. What is wrong?
Thanks.
« Last Edit: September 21, 2016, 04:27:48 AM by qwertysimo »
Re: Mach4 and modbus - help needed
« Reply #1 on: September 21, 2016, 04:30:06 AM »
Can moderator move this topic to Modbus forum, please? Thanks.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #2 on: September 21, 2016, 10:47:30 AM »
If it helps the -27 means  MERROR_REG_NOT_FOUND
DazTheGas
« Reply #3 on: September 21, 2016, 03:05:55 PM »
It does not help. I wrote that information in my first post already.
As a workaround, I do not use coils, I use only holding registers...
Another question - modbus function 0x10, write multiple registers. How to enter several integers in one command?
mc.mcRegSetValue( number hReg, number value )
How to specify "value" to represent several integers for multiple registers?
« Reply #4 on: September 27, 2016, 12:41:11 AM »
BUMP
