Hello Guest it is April 19, 2024, 05:42:05 AM
Author Topic: horizontal bolt pattern  (Read 2069 times)
« on: September 13, 2016, 03:57:00 PM »
whether someone has an idea for a macro script how to do layout for horizontal drilling this is for vertical drilling but should not let the z-10 that, for example, repeated 10 times in the same movement naprimet y30 x0, x0 y0 at a distance of 50 mm.
greeting
Re: horizontal bolt pattern
« Reply #1 on: September 14, 2016, 05:29:08 AM »
Have you tried using one of the Wizards?
ie; Row Bolt Pattern
or
Newfangled Solutions has a linear hole pattern Wizard.
« Reply #2 on: September 14, 2016, 04:03:21 PM »
I've experimented a little bit but I have not found a final solution but if someone has a solution to help
greeting
