Hello Guest it is April 24, 2024, 10:00:33 PM
Author Topic: Debounce  (Read 3704 times)
Debounce
« on: September 05, 2016, 05:34:15 PM »
Hi
I have a question about the debounce setting, A few months back I was having a problem with a program running were it would suddenly stop and I would have to reset  and start running again. It was  recommended that I increase my debounce setting because I probably had some ground issues or perhaps something was unsheilded in my wiring. In reading posts since then I have read that some people have these issues and have theirs set at a variety of numbers. My question is how do these affect how Mach 3 runs when you are not at the ideal 0 setting.
Thanks bill
Re: Debounce
« Reply #1 on: September 05, 2016, 09:18:28 PM »
Debounce will slightly delay any inputs that are triggered.
It really should have any affect on running g-code.
Re: Debounce
« Reply #2 on: February 20, 2017, 02:16:18 PM »
I search the forum for my relative issue and also find another thread:
https://www.machsupport.com/forum/index.php/topic,15570.msg104561.html#msg104561
I think, if installing a small (1uF) capacitor between signal pin and ground can help low debounce to do a good job in homing or probing,
that would be a proper way to run your g-code with low debounce value, especially for some potential EMI problem.
