Hello Guest it is March 28, 2024, 09:49:33 AM
Author Topic: Axis Select  (Read 1999 times)
Axis Select
« on: August 28, 2016, 03:32:11 AM »
Hello,
I use a pokey to control mach3. I want to select with a button the axis for the MPG.
I want to use only one button so at the start X is selected, when i press the button Y is selected and so on
Can somebody help me to realize this idea as simple as possible
best regards
Re: Axis Select
« Reply #1 on: August 28, 2016, 04:39:11 AM »
Which Pokeys do you have?
The u57 (usb) can act as a keyboard emulator, hence a button press on the Pokeys translates to a keyboard keypress.
Hence you can use the hotkeys to perform functions with any coding nessary.
If you have the Ethernet version... no idea...
Rob
