Hello
Guest
it is
April 20, 2024, 09:28:37 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
General CNC Chat
Show"N"Tell ( Your Machines)
MIKRON WF3 RETROFIT
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: MIKRON WF3 RETROFIT (Read 50782 times)
gravie
56
MIKRON WF3 RETROFIT
on:
August 21, 2016, 05:32:35 AM »
My new Project
Mach 3 or 4, Mikron WF3, CS Labs Controller,
Backpack case for the original control panel
Touch screen
Last Edit: August 21, 2016, 05:36:36 AM by gravie
Logged
gravie
56
Re: MIKRON WF3 RETROFIT
Reply #1 on:
August 21, 2016, 05:33:46 AM »
The work after 2 days
Logged
gravie
56
Reply #2 on:
August 21, 2016, 06:04:41 AM »
The big problem is the manual gear box.
I want to use a frequency converter and change only one gear with a belimo actuator......i hope it works.
any other idea?
for the linear scale i use a heidenhain EXE 602 e converter (sinus wave to ttl) box.
Logged
gravie
56
Reply #3 on:
August 21, 2016, 07:22:03 AM »
1. Step
TNC 131 out and CS LABS with Heidenhain EXE602E and frequency inverter in with the original servos.
2. Step
Modify Gearbox and ballscrew spindles
3. Step
DIY Tool Changer
4. Step
4.Axis
Last Edit: August 21, 2016, 07:27:29 AM by gravie
Logged
Carnoustie, Scotland
Reply #4 on:
August 22, 2016, 06:01:48 PM »
Looks like a nice machine, looking forward to seeing the progress
Logged
gravie
56
Reply #5 on:
August 24, 2016, 02:09:38 AM »
i have a question about the BBC servo amp.
mikron use a switch ( phase cange for motor and endcoder) after the servo amp for + and - feed.
but can i use the BBC servo axodyn 05LE amp with +-10volt for + and - feed?
i connect the cs labs io to pin 3 (Vref+) and pin (Vref-).
Last Edit: August 24, 2016, 02:29:10 AM by gravie
Logged
gravie
56
Reply #6 on:
August 24, 2016, 05:36:16 AM »
the motor is a
http://callantechnology.com/callan_technology_products/TT-295X/TT-295X.html
kollmorgen/inland/callan TT2952B.
can i buy an alternativ controller for the servo motor?
i think, the BBC AMP only controll the speed and not the direction.
Logged
gravie
56
Reply #7 on:
August 24, 2016, 04:35:27 PM »
after using google i found the follow motion controller with +-10v input:
Advanced Motion Controls Brush Type PWM Servo Amplifier 12A8K
or
Callan AS-80-8/15 DC SERVO AMPLIFIER
Logged
Reply #8 on:
August 24, 2016, 05:22:24 PM »
I don't think the Amp will only control speed unless it was meant for something like a spindle.
I will have a search and see if I can find a manual for it in English as afraid I do not know German.
Logged
Reply #9 on:
August 24, 2016, 05:30:12 PM »
Ok, it is indeed just a speed controller, was this used on the machine before?
Was it just used as a power feed of some sort?
Logged
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
