Hello Guest it is March 29, 2024, 04:41:30 AM
Author Topic: I help! need some logo  (Read 10744 times)
« on: August 08, 2016, 04:17:23 AM »
hey,
i need gcode and sketch for easy logo at size 90x50x15
onCNC MILL .
  •  9,196 9,196
Re: I help! need some logo
« Reply #1 on: August 08, 2016, 06:22:42 AM »
Post a dxf of the logo you require (highest resolution would be best).
« Reply #2 on: August 08, 2016, 06:52:33 AM »
I dont know how.
i just need it for class. it can be any logo.
there are two requaiment:
1: at least  2 arc with i and j
2: the size  90X50X15
  •  9,196 9,196
« Reply #3 on: August 08, 2016, 07:34:09 AM »
You have to do some of the work yourself - I have no intention of doing it all.
1) Find (or design) a logo of the correct size, containing the required arcs (.bmp would be OK but .dxf preferred).
2) Use the full reply and additional options tabs to post your logo here.
I will convert it into a dxf and produce an engraving toolpath Gcode then post both here for you.
« Reply #4 on: August 08, 2016, 07:38:04 AM »
i will tanks you
« Reply #5 on: August 08, 2016, 08:09:46 AM »
is its ok ?
  •  9,196 9,196
« Reply #6 on: August 08, 2016, 10:15:03 AM »
Sorry to say but that would not be ideal.
It has a background size of 23.8 x 13.2 mm and when scaled up to the required 90 x 50 mm has such poor resolution that it would be unlikely to yield any i and j arcs.
Try to find something of the correct size and of a good resolution.
(You could use a CAD software to create a border 90 x 50 mm then perhaps insert some text with a font that contains arcs - the easiest solution perhaps).
  •  9,196 9,196
« Reply #7 on: August 08, 2016, 10:48:41 AM »
This is an example of what I think you want to achieve...
Initially a logo is found which is close to the required size (internet search).
The logo is then converted to a .dxf and scaled to the desired size (cad software).
A Gcode toolpath is generated from the .dxf (cam software).
« Reply #8 on: August 09, 2016, 06:11:42 PM »
Tweakie, I came across this and hope you could point me in a good direction. I have made my 3 axis cnc router from scratch and very happy with the results so far I have used the done some pocketing and cut files I have downloaded. Now I want to make a drink coaster with Alabama football logo on it. I think this should be a simple enough project, any suggestion on how you would go about this?
Hawk.
  •  9,196 9,196
« Reply #9 on: August 10, 2016, 01:04:42 AM »
It's a process as I outlined in my last post.
Attached is a .png graphic which was converted to a .dxf and then an engraving toolpath (Gcode) created using Vectric.
