Hello
Guest
it is
April 26, 2024, 12:11:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
New mach 3 lathe setup issue
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: New mach 3 lathe setup issue (Read 8901 times)
Theelementofsand
5
on:
July 18, 2016, 09:20:25 PM »
Hello everyone, I am new here and have a question. Forgive me if this has been asked before but upon searching I didn't not find an answer. So I setup my sherline lathe with mach and am having an issue with the wizards, they want to start at the center of the part and cut outwards rather than outside to the center. I'm sure it's an easy fix but what am I missing? It's basically acting as if I were printing a part rather than cutting it.
Thanks ahead of time and let me know if you need any more info.
Ron Ginger
925
Re: New mach 3 lathe setup issue
Reply #1 on:
July 18, 2016, 09:48:48 PM »
I am not exactly sure what you are doing, but If you are using the NFsturn set then just make Xstart and Xend have the values you want for start and end.
Theelementofsand
5
Reply #2 on:
July 18, 2016, 09:52:17 PM »
Now that you say that, that might be exactly my problem, having swapped the start and stop points when I typed them in.
Theelementofsand
5
Reply #3 on:
July 18, 2016, 10:16:13 PM »
I double checked that and my numbers were right on, then I realized I had homed the tool but had left the part at 0,0 on x and y
Ron Ginger
925
Reply #4 on:
July 19, 2016, 07:04:07 AM »
In turn mode there is no Y- it should be X and Z.
Theelementofsand
5
Reply #5 on:
July 19, 2016, 07:25:38 AM »
Sorry that's what I meant
Print
Pages:
1
Go Up
« previous
next »
