Hello Guest it is April 20, 2024, 05:13:01 AM
Author Topic: How to automatically move to a coordinate after G-Code is done?  (Read 3279 times)
I have a part that I cut out of aluminum which is locked down on a jig. I usually cut out 50 - 100 pieces of the same part at a time. My usual routine is to wait until the G-Code is done running, wait for the spindle to raise 0.25 inch per the G-Code, and then manually jog the spindle over to a negative X coordinate so I have room to unscrew the part from the jig. I would like to add the negative X coordinate in the G-Code so I don't have to push the "left arrow" and manually move the spindle out of the way. I would think there is a way for me to add a line at the bottom of the G-Code that does this as part of the the whole G-Code. As an example, I would like to have the spindle move to the coordinates of Z0.25, X-4.3, and Y-2.0 once the part is cut out...how do I do this?
Thanks!
Marshall
Re: How to automatically move to a coordinate after G-Code is done?
« Reply #1 on: July 18, 2016, 09:01:05 PM »
You can just add it manually. Are you looking for a way to have it added automatically?
« Reply #2 on: July 18, 2016, 09:08:29 PM »
Either...how do I add it manually? I know I can open up the actually G-Code in a text program. What would be the text I insert at the end?
Marshall
« Reply #4 on: July 19, 2016, 08:54:52 AM »
Thanks!
So if I wanted my spindle to move to coordinates X-4.3, Y-2.0 after the piece is cut, I would insert the following at the end of the G-Code?
G0 X-4.3 Y-2.0
Is this correct?
Marshall
« Reply #5 on: December 17, 2016, 02:06:52 PM »
Can you not set a work coordiante for that?  G54 should call the distance from parked or home to the 0x, 0y corner of your table. I have noticed that a lot of home builds do not set a home position and use no work coordinate offsets.  Why is that?
« Reply #6 on: December 17, 2016, 05:42:55 PM »
Technically, just about everyone uses work offsets. When they zero the axis to set XY zero, they're setting the offsets for G54.
A lot of hobby users don't use home switches because they don't do anything that requires them.
