Hello Guest it is March 29, 2024, 10:51:37 AM
Author Topic: Soft limits enable Auto limit override  (Read 3685 times)
« on: July 18, 2016, 03:02:48 PM »
Hello,
I use PoKeys57CNC with 4 axis and a switch for each axis.
When the limit is triggered and I press the reset button,
I cannot move the motors (like in picture 1).
If I check shared with limit+, then Auto limit OverRide is activated and I can then move the motors to get out of the limit zone (picture 2).
I cannot save this. When I restart Mach3 I have to repeat those steps to check shared with limit+. Auto limit OverRide is activated in Mach3.
What should  I do?
Thanks!
Offline NeoTO
  •  504 504
    • PoLabs
Re: Soft limits enable Auto limit override
« Reply #1 on: July 18, 2016, 03:55:54 PM »
Manual limit override in Mach3 should temporarily disable the limits. We will check this.
Matevž, PoLabs
« Reply #2 on: July 19, 2016, 11:59:30 AM »
Ok working properly, we upgrade the firmware.
