Hello Guest it is April 25, 2024, 08:14:37 PM
Author Topic: XHc HB04 Pendant Configuration  (Read 8173 times)
« on: July 18, 2016, 12:29:04 PM »
So this is my first post in this forum and I am fairly new to CNC Milling and Mach 3.  However, I've gotten things running pretty well and am pleased with the results I am getting so far.
In addition, I am running the XHc HB04 pendant (MPG) and have an issue.  I have the Macro buttons (1, 2, 3, 6 and 7) set for the functions I want and they work well... after a workaround.  The issue is that when I first start Mach 3, the macro buttons do not function.  The work around is to go into the Config | Config Plugins menu and configure the XHc plugin.  I do not have to make any changes, I just need to go there and then click "OK" on the HB04 plugin screen and on the "Config Plugins" page.  At this point, everything then works well.
So the question is:  Is this a Mach 3 problem or a problem with the plugin itself?  If it is a problem with the plugin, is there any contact info for XHc that anyone is aware of that can help out?
Thanks in advance,
Stephen "Highspeed" Kruse
Re: XHc HB04 Pendant Configuration
« Reply #1 on: July 25, 2016, 03:23:21 PM »
Any ideas anyone?
Highspeed
« Reply #2 on: September 16, 2017, 06:04:03 AM »
Any ideas anyone?
Highspeed
same problem
« Reply #3 on: June 28, 2019, 12:19:55 PM »
Any solution to this problem?
