Hi
I have been running succesfully pokeys57cnc controller to drive my cnc router, but now that i have been trying to get probing to work i have seriously "hit a wall". Whatever settings i have tried it says either no contact with probe or that probe is obstructed. When i check the machine diagnostics and pokeys own input diagnostig it seems work well and in mach it shows that probe input gets activated when i close the switch (i am using NO switch to test the probing function). I took log of what is happening and will past it here so if anyone can help me to find out what is causing this error.
2016-06-29 18:48:54.528 - API: mcCntlEnable(true) called.
2016-06-29 18:48:54.530 - Signal id 1018, (Enable #0), changed from LOW to HIGH.
2016-06-29 18:48:54.541 - Signal id 1019, (Enable #1), changed from LOW to HIGH.
2016-06-29 18:48:54.548 - [PoKeys] Axis enabled changed 1
2016-06-29 18:48:54.552 - Signal id 1020, (Enable #2), changed from LOW to HIGH.
2016-06-29 18:48:54.564 - [PoKeys] Updating enable output signals
2016-06-29 18:48:54.569 - Signal id 1021, (Enable #3), changed from LOW to HIGH.
2016-06-29 18:48:54.583 - [PoKeys] Axis enabled changed 7
2016-06-29 18:48:54.586 - Signal id 1120, (Machine Enabled), changed from LOW to HIGH.
2016-06-29 18:48:54.596 - [PoKeys] Updating enable output signals
2016-06-29 18:48:54.612 - [PoKeys] Axis enabled changed 15
2016-06-29 18:48:54.627 - [PoKeys] Updating enable output signals
2016-06-29 18:48:54.640 - [PoKeys] PoKeys Pulse engine enabled
2016-06-29 18:48:54.652 - [PoKeys] Enabling motion - Buffer with 0 moves is being cleared!
2016-06-29 18:48:54.668 - [PoKeys] Updating motion parameters in device
2016-06-29 18:48:54.706 - All motors marked as still.
2016-06-29 18:48:54.707 - All motors marked as still.
2016-06-29 18:48:54.708 - All motors marked as still.
2016-06-29 18:48:54.709 - All motors marked as still.
2016-06-29 18:48:54.710 - API: mcMotionSync() called.
2016-06-29 18:48:54.710 - SyncPosition()! Clearing planner.
2016-06-29 18:48:54.710 - [PoKeys] Switching to RUNNING state...
2016-06-29 18:48:59.644 - API: mcCntlGcodeExecuteWait() called. (G0 G90 G40 G80)
2016-06-29 18:48:59.848 - Attempt transition from "Idle" on event "MDI Start" Controller.cpp:1961
2016-06-29 18:48:59.849 - S_IDLE_on_exit
2016-06-29 18:48:59.849 - MACH_STATE_start_mdi
2016-06-29 18:48:59.849 - S_MDI_RUNNING_on_entry
2016-06-29 18:48:59.849 - S_MDI_RUNNING2_on_entry
2016-06-29 18:48:59.851 - Signal id 1114, (Gcode Running), changed from LOW to HIGH.
2016-06-29 18:48:59.966 - Attempt transition from "MDI Running" on event "Stop" GcodeExec.cpp:943
2016-06-29 18:48:59.966 - S_MDI_RUNNING2_on_exit
2016-06-29 18:48:59.966 - Signal id 1114, (Gcode Running), changed from HIGH to LOW.
2016-06-29 18:48:59.967 - S_MDI_RUNNING_on_exit
2016-06-29 18:48:59.967 - MACH_STATE_stop
2016-06-29 18:49:00.035 - S_IDLE_on_entry
2016-06-29 18:49:00.036 - API: mcCntlGcodeExecuteWait() called. (G43 H1)
2016-06-29 18:49:00.241 - Attempt transition from "Idle" on event "MDI Start" Controller.cpp:1961
2016-06-29 18:49:00.241 - S_IDLE_on_exit
2016-06-29 18:49:00.241 - MACH_STATE_start_mdi
2016-06-29 18:49:00.241 - S_MDI_RUNNING_on_entry
2016-06-29 18:49:00.241 - S_MDI_RUNNING2_on_entry
2016-06-29 18:49:00.242 - Signal id 1114, (Gcode Running), changed from LOW to HIGH.
2016-06-29 18:49:00.362 - Attempt transition from "MDI Running" on event "Stop" GcodeExec.cpp:943
2016-06-29 18:49:00.362 - S_MDI_RUNNING2_on_exit
2016-06-29 18:49:00.362 - Signal id 1114, (Gcode Running), changed from HIGH to LOW.
2016-06-29 18:49:00.363 - S_MDI_RUNNING_on_exit
2016-06-29 18:49:00.363 - MACH_STATE_stop
2016-06-29 18:49:00.426 - S_IDLE_on_entry
2016-06-29 18:49:00.428 - API: mcCntlGcodeExecuteWait() called. (G31,0 Z-50,5000 F50,0)
2016-06-29 18:49:00.632 - Attempt transition from "Idle" on event "MDI Start" Controller.cpp:1961
2016-06-29 18:49:00.632 - S_IDLE_on_exit
2016-06-29 18:49:00.632 - MACH_STATE_start_mdi
2016-06-29 18:49:00.632 - S_MDI_RUNNING_on_entry
2016-06-29 18:49:00.633 - S_MDI_RUNNING2_on_entry
2016-06-29 18:49:00.634 - Signal id 1114, (Gcode Running), changed from LOW to HIGH.
2016-06-29 18:49:00.649 - Attempt transition from "MDI Running" on event "Stop" GcodeExec.cpp:994
2016-06-29 18:49:00.649 - S_MDI_RUNNING2_on_exit
2016-06-29 18:49:00.649 - Signal id 1114, (Gcode Running), changed from HIGH to LOW.
2016-06-29 18:49:00.650 - S_MDI_RUNNING_on_exit
2016-06-29 18:49:00.650 - MACH_STATE_stop
2016-06-29 18:49:00.712 - S_IDLE_on_entry
2016-06-29 18:49:00.714 - API: mcCntlEStop() called.
2016-06-29 18:49:00.715 - API: mcCntlEnable(false) called.
2016-06-29 18:49:00.718 - Signal id 1018, (Enable #0), changed from HIGH to LOW.
2016-06-29 18:49:00.733 - Signal id 1019, (Enable #1), changed from HIGH to LOW.
2016-06-29 18:49:00.735 - [PoKeys] Axis enabled changed 14
2016-06-29 18:49:00.744 - Signal id 1020, (Enable #2), changed from HIGH to LOW.
2016-06-29 18:49:00.751 - [PoKeys] Updating enable output signals
2016-06-29 18:49:00.761 - Signal id 1021, (Enable #3), changed from HIGH to LOW.
2016-06-29 18:49:00.779 - [PoKeys] Axis enabled changed 8
2016-06-29 18:49:00.781 - Signal id 1120, (Machine Enabled), changed from HIGH to LOW.
2016-06-29 18:49:00.789 - [PoKeys] Updating enable output signals
2016-06-29 18:49:00.818 - [PoKeys] Axis enabled changed 0
2016-06-29 18:49:00.834 - [PoKeys] Updating enable output signals
2016-06-29 18:49:00.850 - [PoKeys] PoKeys Pulse engine disabled
2016-06-29 18:49:00.864 - [PoKeys] Disabling motion - Buffer with 0 moves is being cleared!
