Hello Guest it is April 23, 2024, 08:54:55 PM
Author Topic: SAFE Z SETTINGS?  (Read 2455 times)
SAFE Z SETTINGS?
« on: June 22, 2016, 09:24:19 PM »
Could someone explain what Safe Z is, what it does, and where should it be set?
Re: SAFE Z SETTINGS?
« Reply #1 on: June 24, 2016, 07:26:08 PM »
Safe Z, means just what it sounds like. It is a position to which the Z axis is retracted, which will not crash the tool into anything. This is usually just below the home/limit switch of the Z. In the menu, you can set the Safe Z position relative to Home 0.000, or a distance in units just below the home. I set mine to .050" below home. Also, you can set the action for the machine to go to Safe Z if you hit the stop button.
« Reply #2 on: June 24, 2016, 08:02:51 PM »
Thanks for clearing that up for me.
