Hello Guest it is May 10, 2024, 12:34:45 AM
Author Topic: CNC Router Retrofit to CSMIO/IP-S  (Read 4797 times)
« on: June 14, 2016, 04:47:17 PM »
I'm in the process of retrofitting a 1212 CNC Router motion control to CSMIO/IP-S.  The machine is currently up an running with the import BOB.  I just need to verify connection to the VFD. I'm currently able to control spindle on/off and spindle rpm.
Here is the current BOB connections.
BOB         VFD
0-10v        AI
GND         CM
COM         CM
P2            FWD
Here is what I believe it needs to be on with CSMIO/IP-S.  Please help me if this is not correct.
IP-S                             VFD
Analog 0-10v (Pin 1)       AI
GND (Pin 2)                   CM
Digital Out 0V(Pin14)      CM
Digital Out 0 (pin 0)        FWD
Thanks, Jon
