It should be really simple - open the PoKeys plugin configuration, switch to PWM tab in the settings, enter the PWM period in microseconds, then select what you want to do with each PWM channel. Simplest is to use the 'Map to DRO in %', which will use the selected DRO's value (multiplied with the optional multiplier setting) as the channels duty cycle.
