Hello Guest it is April 25, 2024, 06:02:57 AM
Author Topic: Pokeys 57E Soft Limits  (Read 2538 times)
« on: June 02, 2016, 07:15:01 AM »
Pokeys57E and MachMotion Apollo III (Model X15-A3-V1.0)
When I use the Jog buttons on the Pokeys57E the Soft Limits do not seem work. Is this a setup problem?
Thank you,
Jerry D
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys 57E Soft Limits
« Reply #1 on: June 18, 2016, 03:37:45 PM »
The soft limits in Mach3 are usually handled by the motion controller device directly. If I understand you correctly, the PoKeys57E device is used as an input device - in this case, it only forwards the information to Mach3, so either Mach3 or Apollo should take care of the soft limits.
