Hello Guest it is April 26, 2024, 11:25:13 PM
Author Topic: Pokeys57CNC Strange Jogging Behaviour  (Read 4000 times)
« on: May 31, 2016, 06:02:40 AM »
Using pokeys 4.1.64, Mach3 xx.066. Having a strange behaviour. Mostly happens after homing not limited to it. Home the axis, then jog the axis off the switch using the keyboard, release the arrow key and the axis bumps and stops as if there was no deceleration. On subsequent jog moves it would act normally, i.e. decelerating according to the defined rate to a stop. Occasionally it would happen again, but as I said, mostly (not always happens here too) after homing was issued.
Seems like a bug to me.
Re: Pokeys57CNC Strange Jogging Behaviour
« Reply #1 on: June 04, 2016, 08:57:11 PM »
i also noticed it .. like it comes to an abrupt stop. i have since upgraded to mach4 and have not noticed it again.
« Reply #2 on: June 05, 2016, 03:16:54 AM »
OK. So it's not just me. Thanks for your input. I would like to know what the manufacturer has to say, but seems they're not around here.
« Reply #3 on: September 25, 2016, 09:24:20 AM »
yes, same problem to me..... it happens sometime and I was not able to understand where the problem is.
« Reply #4 on: September 25, 2016, 10:15:45 AM »
They sent me a new plugin a couple of months ago that was supposed to fix this, but the problem still persists.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #5 on: October 23, 2016, 01:29:41 AM »
This should have been resolved in one of the last plugin versions. Previously, the device was left with invalid deceleration values setup after homing was completed.
