Hello Guest it is March 29, 2024, 05:10:26 AM
Author Topic: Plasma calculator screenset  (Read 5966 times)
« on: May 30, 2016, 06:52:35 AM »
I developed the screen 3 years ago for our plasma routers, but it still can be interesting for everyone who work with plasma routers.
It is parametric engine behind the screen to calculate Feed, THC voltage, Pierce height and delays, Kerf etc.
Mainly for Hypertherm, Thermal Dynamics plasma cutters, but works for bunch of HF start torches too, like A141, S105
The results for Powermax is about 2% dispersion to the cutting charts.
Work for metric and imperial units, gauge sheets.
The same parametric engine used for some our other projects -- ios, android, grbl, integrated controllers.
I'm wondering, if anyone interested for the same screen for Mach4.
Re: Plasma calculator screenset
« Reply #1 on: February 22, 2023, 08:38:44 AM »
I see that the parameters can be changed while a G-code is running, should't be locked while a command is running ?
regards
