Hello
Guest
it is
April 26, 2024, 10:25:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
After update to 4.1.65 Homing problems
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: After update to 4.1.65 Homing problems (Read 2836 times)
GerdS
42
on:
May 28, 2016, 01:57:42 PM »
I just updated my controller to new version 4.1.65.
But now the Homing function works not like before.
Unfortunally i killed my X Axis sensor.
It looks like the homing does not stop the motors immediately after the signal comes.
My X home switch is also the end switch therefore i have just a few mm for stop.
After downgrate to an earlier Firmware version all is Ok again.
Logged
NeoTO
504
Re: After update to 4.1.65 Homing problems
Reply #1 on:
May 29, 2016, 02:30:39 AM »
Hi, Gerd
The update 4.1.65 will be pulled and a fix will be released immediately.
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
GerdS
42
Reply #2 on:
May 29, 2016, 05:39:10 AM »
Ok, fine.
Could you find a solution for the Motion step Overflow issue already. ?
If you need somebody for tests, i can do this for you.
Gerd
Logged
NeoTO
504
Reply #3 on:
May 29, 2016, 11:10:03 AM »
Unfortunately, we are still working on determining the cause for the steps overflow issue. I think we will have the fix soon.
Logged
www.poscope.com
Print
Pages:
1
Go Up
« previous
next »
