Hello Guest it is April 19, 2024, 07:50:51 AM
Author Topic: Softlimit bad behavior while massive probing  (Read 4553 times)
« on: May 23, 2016, 08:42:04 AM »
As im building Plasma routers and want to use Mach3 as gcode interpretor i met a problem
After loading a programm with multiple touch and go operations (Probings)  the simulated z-max is rising every hole on loading the gcode for 5mm (my cutting height).
On Start of the programm now the typical softlimit zmax error message appears which i need to accept.
In normal cutting operation this never happens, because for every hole the axis is referenced new, and i never hit the softlimit
Is there any way to automatical accept the Softlimit warning box without disabling the softlimit for Z, or a compensation for the virtual probing?
Roll Eyes  Roll Eyes  Roll Eyes
contact: rene@marhold.net
example: with zmax softlimit at 150mm
N0010 (Filename: Draft241.tap)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 20.05.2016)
N0040 G21 (Units: Metric)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: Draft24)
N0080 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N0090 G00 X48.8000 Y48.8000
N0100 G28.1 Z3.00 F500.0
N0110 G92 Z0.0
N0120 G00 Z1.5000
N0130 G92 Z0.0
N0140 G00 Z6.5000
N0150 M03
N0160 G01 Z4.8000 F200.0
N0170 Y1.2000 F250.0
N0180 X1.2000
N0190 Y48.8000
N0200 X48.8000
N0210 (Part: Draft24 Duplizieren 1)
N0220 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N0230 M05
N0240 G04 P0.5
N0250 G00 Z50.0000
N0260 Y108.8000
N0270 G28.1 Z3.00 F500.0
N0280 G92 Z0.0
N0290 G00 Z1.5000
N0300 G92 Z0.0
N0310 G00 Z6.5000
N0320 M03
N0330 G01 Z4.8000 F200.0
N0340 Y61.2000 F250.0
N0350 X1.2000
N0360 Y108.8000
N0370 X48.8000
N0380 (Part: Draft24 Duplizieren 2)
N0390 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N0400 M05
N0410 G04 P0.5
N0420 G00 Z50.0000
N0430 Y168.8000
N0440 G28.1 Z3.00 F500.0
N0450 G92 Z0.0
N0460 G00 Z1.5000
N0470 G92 Z0.0
N0480 G00 Z6.5000
N0490 M03
N0500 G01 Z4.8000 F200.0
N0510 Y121.2000 F250.0
N0520 X1.2000
N0530 Y168.8000
N0540 X48.8000
N0550 (Part: Draft24 Duplizieren 3)
N0560 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N0570 M05
N0580 G04 P0.5
N0590 G00 Z50.0000
N0600 Y228.8000
N0610 G28.1 Z3.00 F500.0
N0620 G92 Z0.0
N0630 G00 Z1.5000
N0640 G92 Z0.0
N0650 G00 Z6.5000
N0660 M03
N0670 G01 Z4.8000 F200.0
N0680 Y181.2000 F250.0
N0690 X1.2000
N0700 Y228.8000
N0710 X48.8000
N0720 (Part: Draft24 Duplizieren 7)
N0730 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N0740 M05
N0750 G04 P0.5
N0760 G00 Z50.0000
N0770 X108.8000
N0780 G28.1 Z3.00 F500.0
N0790 G92 Z0.0
N0800 G00 Z1.5000
N0810 G92 Z0.0
N0820 G00 Z6.5000
N0830 M03
N0840 G01 Z4.8000 F200.0
N0850 Y181.2000 F250.0
N0860 X61.2000
N0870 Y228.8000
N0880 X108.8000
N0890 (Part: Draft24 Duplizieren 6)
N0900 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N0910 M05
N0920 G04 P0.5
N0930 G00 Z50.0000
N0940 Y168.8000
N0950 G28.1 Z3.00 F500.0
N0960 G92 Z0.0
N0970 G00 Z1.5000
N0980 G92 Z0.0
N0990 G00 Z6.5000
N1000 M03
N1010 G01 Z4.8000 F200.0
N1020 Y121.2000 F250.0
N1030 X61.2000
N1040 Y168.8000
N1050 X108.8000
N1060 (Part: Draft24 Duplizieren 5)
N1070 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N1080 M05
N1090 G04 P0.5
N1100 G00 Z50.0000
N1110 Y108.8000
N1120 G28.1 Z3.00 F500.0
N1130 G92 Z0.0
N1140 G00 Z1.5000
N1150 G92 Z0.0
N1160 G00 Z6.5000
N1170 M03
N1180 G01 Z4.8000 F200.0
N1190 Y61.2000 F250.0
N1200 X61.2000
N1210 Y108.8000
N1220 X108.8000
N1230 (Part: Draft24 Duplizieren 4)
N1240 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N1250 M05
N1260 G04 P0.5
N1270 G00 Z50.0000
N1280 Y48.8000
N1290 G28.1 Z3.00 F500.0
N1300 G92 Z0.0
N1310 G00 Z1.5000
N1320 G92 Z0.0
N1330 G00 Z6.5000
N1340 M03
N1350 G01 Z4.8000 F200.0
N1360 Y1.2000 F250.0
N1370 X61.2000
N1380 Y48.8000
N1390 X108.8000
N1400 (Part: Draft24 Duplizieren Cool
N1410 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N1420 M05
N1430 G04 P0.5
N1440 G00 Z50.0000
N1450 X168.8000
N1460 G28.1 Z3.00 F500.0
N1470 G92 Z0.0
N1480 G00 Z1.5000
N1490 G92 Z0.0
N1500 G00 Z6.5000
N1510 M03
N1520 G01 Z4.8000 F200.0
N1530 Y1.2000 F250.0
N1540 X121.2000
N1550 Y48.8000
N1560 X168.8000
N1570 (Part: Draft24 Duplizieren 9)
N1580 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N1590 M05
N1600 G04 P0.5
N1610 G00 Z50.0000
N1620 Y108.8000
N1630 G28.1 Z3.00 F500.0
N1640 G92 Z0.0
N1650 G00 Z1.5000
N1660 G92 Z0.0
N1670 G00 Z6.5000
N1680 M03
N1690 G01 Z4.8000 F200.0
N1700 Y61.2000 F250.0
N1710 X121.2000
N1720 Y108.8000
N1730 X168.8000
N1740 (Part: Draft24 Duplizieren 10)
N1750 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N1760 M05
N1770 G04 P0.5
N1780 G00 Z50.0000
N1790 Y168.8000
N1800 G28.1 Z3.00 F500.0
N1810 G92 Z0.0
N1820 G00 Z1.5000
N1830 G92 Z0.0
N1840 G00 Z6.5000
N1850 M03
N1860 G01 Z4.8000 F200.0
N1870 Y121.2000 F250.0
N1880 X121.2000
N1890 Y168.8000
N1900 X168.8000
N1910 (Part: Draft24 Duplizieren 11)
N1920 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N1930 M05
N1940 G04 P0.5
N1950 G00 Z50.0000
N1960 Y228.8000
N1970 G28.1 Z3.00 F500.0
N1980 G92 Z0.0
N1990 G00 Z1.5000
N2000 G92 Z0.0
N2010 G00 Z6.5000
N2020 M03
N2030 G01 Z4.8000 F200.0
N2040 Y181.2000 F250.0
N2050 X121.2000
N2060 Y228.8000
N2070 X168.8000
N2080 (Part: Draft24 Duplizieren 15)
N2090 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N2100 M05
N2110 G04 P0.5
N2120 G00 Z50.0000
N2130 X228.8000
N2140 G28.1 Z3.00 F500.0
N2150 G92 Z0.0
N2160 G00 Z1.5000
N2170 G92 Z0.0
N2180 G00 Z6.5000
N2190 M03
N2200 G01 Z4.8000 F200.0
N2210 Y181.2000 F250.0
N2220 X181.2000
N2230 Y228.8000
N2240 X228.8000
N2250 (Part: Draft24 Duplizieren 14)
N2260 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N2270 M05
N2280 G04 P0.5
N2290 G00 Z50.0000
N2300 Y168.8000
N2310 G28.1 Z3.00 F500.0
N2320 G92 Z0.0
N2330 G00 Z1.5000
N2340 G92 Z0.0
N2350 G00 Z6.5000
N2360 M03
N2370 G01 Z4.8000 F200.0
N2380 Y121.2000 F250.0
N2390 X181.2000
N2400 Y168.8000
N2410 X228.8000
N2420 (Part: Draft24 Duplizieren 13)
N2430 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N2440 M05
N2450 G04 P0.5
N2460 G00 Z50.0000
N2470 Y108.8000
N2480 G28.1 Z3.00 F500.0
N2490 G92 Z0.0
N2500 G00 Z1.5000
N2510 G92 Z0.0
N2520 G00 Z6.5000
N2530 M03
N2540 G01 Z4.8000 F200.0
N2550 Y61.2000 F250.0
N2560 X181.2000
N2570 Y108.8000
N2580 X228.8000
N2590 (Part: Draft24 Duplizieren 12)
N2600 (Operation: Innerhalb Offset, Colour 7, T10: S235 20mm 140V 100A)
N2610 M05
N2620 G04 P0.5
N2630 G00 Z50.0000
N2640 Y48.8000
N2650 G28.1 Z3.00 F500.0
N2660 G92 Z0.0
N2670 G00 Z1.5000
N2680 G92 Z0.0
N2690 G00 Z6.5000
N2700 M03
N2710 G01 Z4.8000 F200.0
N2720 Y1.2000 F250.0
N2730 X181.2000
N2740 Y48.8000
N2750 X228.8000
N2760 M05
N2770 G04 P0.5
N2780 G00 Z50.0000
N2790 X0.0000 Y0.0000
N2800 M05 M30
