Hello Guest it is April 24, 2024, 08:43:00 PM
Author Topic: DDCM6V5.0 Breakout Board  (Read 8068 times)
« on: May 21, 2016, 04:26:53 PM »
I recently purchased a DDCM6V5.0 Breakout Board on EBay.  before it arrived, I updated my system to 64-Bit.  As Mach-3 will not run on a 64-Bit I plan to use Mach-4.  However, the disk that came with the Breakout Board has all I need to run on Mach-3, but Mach-4.  It seems I need a Plugin file that I dont have.   Does anyone have this file?  I am waiting to hear back from the Company I bought the board from, but am impatient.    Thanks
  •  9,199 9,199
Re: DDCM6V5.0 Breakout Board
« Reply #1 on: May 22, 2016, 01:48:54 AM »
That board will work OK with Mach3 (It is only the parallel port operation that will not work with 64 bit systems).
It is unlikely that a Mach4 plugin for that board will be available any time soon.
« Reply #2 on: May 22, 2016, 04:03:12 PM »
It is good to hear that the board will work with Mach3 from you (as well as the seller).   So,  How well will Mach3 run on a Win7 pro  64-Bit system?
« Reply #3 on: May 22, 2016, 04:27:45 PM »
I have mach3 running under Win 7 pro no problems there, but I did have problems with that board from eBay and had to return for refund as it was faulty and supplied disk infected my system with a Trojan. So check the disk carefully and do not worry you can return it for a refund purely on the grounds they all tend to ship this board with counterfeit software, if anything like one supplied to me containing nasty surprises.
« Reply #4 on: May 22, 2016, 05:10:17 PM »
I know I can run the Mach3 software on Win7 Pro 32-bit.  But as I said in my first post, I upgraded my system to 64-bit.  And the Mach3 page reads like it will not run properly  on a 64-bit system.  Or is that only if I an using a Parallel port, instead of the USB port I plan on using.
Offline dude1
  •  1,253 1,253
« Reply #5 on: May 22, 2016, 05:27:25 PM »
it's as Tweakie Said parallel port needs a 32 bit computer up to win 7. 8 and up needs a external controller
« Reply #6 on: May 22, 2016, 05:38:25 PM »
OK then,  I should be good to go.  I'll post the results after I try it out.
« Reply #7 on: May 27, 2016, 06:38:49 PM »
I am having communication issues with the seller. Language barrier and all.  The DDCM6V board I bought has different labels for its terminals.  No surprise there.
 So  What do the following labels stand for?  S 0  : S 1  : S 2  :  S 3  : Z_Se  : Y_Se  : X_Se  :
