Hello
Guest
it is
April 23, 2024, 09:19:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Close Loop Analog Spindle (0-10v), Pokeys57CNC, Mach4 Mill, Encoder (A/B/I)
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Close Loop Analog Spindle (0-10v), Pokeys57CNC, Mach4 Mill, Encoder (A/B/I) (Read 2951 times)
miamicraft
1
on:
May 17, 2016, 04:00:59 PM »
I have a mill with an analog spindle (0-10 volt) and an encoder. Does the Pokeys57CNC plugin/Mach4 allow me to close the loop between commanded spindle speed and actual speed? If so can you please point me to some documentation?
Roger
Logged
NeoTO
504
Re: Close Loop Analog Spindle (0-10v), Pokeys57CNC, Mach4 Mill, Encoder (A/B/I)
Reply #1 on:
May 18, 2016, 11:23:26 AM »
Hi, Roger
The PoKeys57CNC by itself does not (yet) support the closed-loop control of the spindle speed.
However, one can realize this using the PLC LUA scripting in Mach4 - the spindle speed measurement are done by PoKeys57CNC and sent to Mach4. One can read the current spindle speed and adjust the PWM output of the PoKeys device that drives the spindle (via analog output).
Unfortunately, we don't have any example on how this is done, but will suggest my colleague to prepare an article on our blog (
http://blog.poscope.com
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Print
Pages:
1
Go Up
« previous
next »
