Hello
Guest
it is
April 18, 2024, 10:02:23 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach4 Axis Calibration...
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach4 Axis Calibration... (Read 5424 times)
mjohnson
17
on:
May 13, 2016, 03:37:06 AM »
I saw some discussion about Mach4 not having the same calibration wizard to calibrate your axis steps that Mach3 has. Those discussions are a year old now, did that ever get implemented into Mach4?
Logged
royce
40
Re: Mach4 Axis Calibration...
Reply #1 on:
May 13, 2016, 07:13:01 AM »
No, and from what I heard it won't be. Its more or so a mechanical equation with no calibrating needed, ez pz leon squeezy. Daz did put up a video on youtube of configuring motors in Mach4 .
Logged
Bridgeport Series 1 Rigid Ram Retrofitted w/PMDX126 BOB, PMDX107, Hitachi WJ200 VFD,ESS, Leadshine DM2282 Drivers running Mach4 comfortably.
mjohnson
17
Reply #2 on:
May 13, 2016, 09:52:04 AM »
Thanks Royce, a search in Youtube did not seem to return a Mach4 calibration video, do you happen to have a link to it? I found a link in a thread but it was broken.
Logged
royce
40
Reply #3 on:
May 13, 2016, 09:57:03 AM »
Here you go.
https://youtu.be/HIE0k6mu2yc?t=9m45s
He is using ESS but the axis setup configuration is modified in Mach 4, not the plugin.
Logged
bob_at_pmdx
151
Reply #4 on:
May 13, 2016, 10:14:35 AM »
In case people want other helpful videos, a reminder that this link is the one referenced in the "Mach4 Videos" sub-section of this forum under the title "ESS and Mach4 Setup" here:
https://www.machsupport.com/forum/index.php/topic,29878.0.html
Logged
brummettm58
1
Reply #5 on:
August 24, 2017, 07:49:58 PM »
Did you get an update on the missing calibration issue? Everything is old that I can find.
Logged
Mauri
328
Reply #6 on:
August 24, 2017, 11:48:29 PM »
There is a Wizard in Mach4 "StepPerUnitCalculatorBasic".
Mauri
Logged
gorf23
189
Reply #7 on:
August 30, 2017, 09:34:29 AM »
CountsPerUnit, rc = mc.mcProfileGetDouble(inst,"Motor0", "CountsPerUnit", 2000.0)
this works for changing the CountsPerUnit but if you only want to read the CountsPerUnit to a variable
how would that be done?
Thanks gary
Logged
Mauri
328
Reply #8 on:
September 06, 2017, 10:10:03 PM »
gorf23,
This is my version of Ball Screw Calibration for Mach4.
Mauri.
Logged
gorf23
189
Reply #9 on:
September 08, 2017, 05:57:05 PM »
that looks good thanks
Do you have the code to write and read from and to the proper position of the ini file?
Thanks gary
Logged
Print
Pages:
1
Go Up
« previous
next »
