Hello Guest it is April 16, 2024, 11:29:48 AM
Author Topic: Program stalls then continues.  (Read 5600 times)
« on: April 26, 2016, 07:59:32 AM »
Hello, I am having a strange thing happening with my Galil DMC 4163 and Mach3. Sometimes as a program is running, the motion just stops for a few seconds during a move then continues like nothing has happened. Usually not a big deal unless it's during a finish cut where stopping is visible. I am using XP connected through ethernet to my Galil. I would suspect that Mach is giving a zero speed command to Galil at a random point while the computer or Mach thinks about something. To my knowledge of Galil programming, the only way to stop and start motion during a commanded move, is the SP0 (zero speed) command to that axis. I have found no pattern as to when this happens. Has anyone else seen this and does anyone have a method to test or fix it? Thanks for your time, Allen
Re: Program stalls then continues.
« Reply #1 on: November 18, 2018, 09:21:22 PM »
Allen,
I was wondering if you found the cause for the pausing of your system.  I recently got my machine up and running with MACH4 and Galil  DMC-4143 and have experienced similar behavior.  I believe the problem is more prevelant when I run in > 100% feed override but that may be a coincidence.  Anyway interested to know if you resolved.
Jeff
« Reply #2 on: November 20, 2018, 10:09:06 AM »
Jeff,
I have not found a solution. I don't see any difference with a change in buffering or any feedrate. I doubt it is in the Galil as I run several Galil controllers and the only one that does this is with Mach.
