Hello Guest it is April 26, 2024, 08:37:51 PM
Author Topic: Pokeys57E,Mach4 External Push Button  (Read 7771 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
« on: April 23, 2016, 12:05:55 PM »
Hello,
 Does anyone have an example of how to configure Mach4&Pokeys57E plugin for a External Push button or switch? Example: I have Pokeys pin 28 set as Digital Input, which is wired to my Cycle Start button. How do you configure plugin and Mach4 so Mach4 knows this input is Cycle Start?
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys57E,Mach4 External Push Button
« Reply #1 on: April 25, 2016, 04:29:48 PM »
Hi, Troy
Please follow the tutorial on our blog page: http://blog.poscope.com/mach4-tutorial-custom-signal-mapping/
Matevž
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #2 on: April 26, 2016, 07:14:40 AM »
Hello Matevz,
 That looks great :) I will reply back here with results.
Thanks again,
Troy
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #3 on: April 26, 2016, 03:43:14 PM »
Ok. Tutorial worked great, as Cycle Start button is now working. Thought i could use this tutorial for all my other inputs by copying the code for CycleStart and just change the ISIP input and the CycleStart() like below for CycleStop....
[mc.ISIG_INPUT27] = function (state)
if (state == 1) then
        CycleStop()
    end
but did not work.
I have more external buttons and switches to add like the CycleStart, is there a list or literature i should be referring to for the LUA script and Mach4 commands? Iam only somewhat familiar with Mach3 and the OEM codes in VisualBasic. Any help is much appreciated.
Troy
Offline dude1
  •  1,253 1,253
« Reply #4 on: April 26, 2016, 07:52:10 PM »
there is a Mach4 programming manual in the manual folder in the Mach4 folder on your C drive
you will have to make a table
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #5 on: April 27, 2016, 11:03:33 AM »
I read the manual and found a short description of a Table, but not enough info for me on how to make one or where to place it and how to use it. Is there a example on how to make one for adding more inputs for physical external buttons and switches?
« Last Edit: April 27, 2016, 11:05:06 AM by TDAY »
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #6 on: April 27, 2016, 12:10:42 PM »
If you look at the code in the script, you will notice that you have somewhere in the beginning
Code: [Select]
-- Signal Library
SigLib = {
Then, one block as following for each signal
Code: [Select]
[mc.<signal name>] = function (state)
 < code >
end
So, SigLib is a Table name, which contains handler functions for all signals in the list. The SigLib ends somewhere later on (around row 70) with a '}'
To add a new signal handler, make sure that you insert it in the Table and that you put a comma at the end of it.
Code: [Select]
-- Signal Library
SigLib = {
[mc.SIGNAL1] = function (state)
 < code >
end,
[mc.SIGNAL2] = function (state)
 < code >
end,
[mc.SIGNAL3] = function (state)
 < code >
end,
[mc.SIGNALn] = function (state)
 < code >
end
« Last Edit: April 27, 2016, 12:37:48 PM by NeoTO »
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #7 on: April 27, 2016, 03:59:22 PM »
Here is what i tried to do for CycleStop....
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #8 on: April 27, 2016, 04:01:02 PM »
But when i press the external cycle stop during a Gcode MDI run i get the following error.....
Offline dude1
  •  1,253 1,253
« Reply #9 on: April 27, 2016, 04:08:04 PM »
have it in it's own section the end end stops the table and state 1 on, state 0 off
