Hello Guest it is April 25, 2024, 03:54:28 PM
Author Topic: Pokeys57E,Mach4 External Push Button  (Read 7758 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: Pokeys57E,Mach4 External Push Button
« Reply #10 on: April 28, 2016, 02:24:02 PM »
I dont understand what you are saying...
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Offline dude1
  •  1,253 1,253
« Reply #11 on: April 28, 2016, 03:35:54 PM »
how NeoTO says to have is how it is to be done not like what you have
« Reply #12 on: April 29, 2016, 08:27:54 AM »
TDAY, if you would like  I can post how to do it... you should be able to modify the other output to make it work. You will find with this system you can do ANYTHING. But the cost is it is a bit more complex.
Looked again at your error and it is nothing to do with your signal script. You are calling set last error and not sending the Inst , String . Please look at your code in the CycleStop() function. If you post a screen shot we can have a look at it .
« Last Edit: April 29, 2016, 08:39:10 AM by Brian Barker »
www.newfangledsolutions.com
www.machsupport.com
