Hello Guest it is April 26, 2024, 09:11:29 AM
Author Topic: y axis off centre after rotation  (Read 1606 times)
« on: April 18, 2016, 07:46:19 AM »
Hi Guys,
I have a 4 axis machine and been using it with for a few years now. I have a noticed problem that has got me tossed. My centre of rotation is along the Y axis. After setting my zero points (x, y, z, a) and confirming that there is no misalignment between the  indexer and the tail-stock, when I initiate the run sequence, the piece is machined off centre by about 1mm. I am using Rhinocam and Mach3 though a Gecko controller. After a couple of days of checking all settings in both programs, there is nothing that looks out of place. I have never noticed this error before, so whether it is a new development or not I don't know. Problem is, if I machine the top surface, then rotate 180 degrees, the misalignment then totals 2mm. I am not too sure but could tool compensation be causing this issue?
I have posted an image that I found on another forum where a fellow was having the same issue when trying to machine a square end on a table leg. Unfortunately there was no final result/solution posted so I do not know the final outcome and there is no way to contact the person concerned.
So if anyone has experienced this, or knows of this issue and has an answer I would be most appreciative.
Thank you all in advance.
Phil
« Last Edit: April 18, 2016, 07:50:39 AM by prdp141 »
(No subject)
« Reply #1 on: April 19, 2016, 11:55:34 AM »
What happens if you where to index and machine 4 sides ?  Will it be a total of 4mm off (from first side to last).
How is your program set up, are the corridents a sub program and you just index and call the sub programs a second time ?
Can you post the program ?
~ What was once an Opinion, became a Fact, to be later proven Wrong ~
