July 18, 2018, 11:27:18 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Sieg Machines
| | |-+  seig kx 1 not moving
Pages: 1   Go Down
Print
Author Topic: seig kx 1 not moving  (Read 36440 times)
bab160
Holding
Offline Offline
View Profile
« on: April 12, 2016, 02:52:19 PM »
Hi
i just bough an used kx1 milling machine and now i am trying to get it to work so installed the software from smallcnc and the xml fil for parralel port use
now the mille reacts to emergency key and the driver test say perfekt condiotions  the spindle drive on small pulses just making small turns an the steppers is making a whistling sound none these reacts to joggnig or setiing spindel speed the to only ting reacting is emergency stop ports are setup like bios =epp and the adress is 378.
i used the xlm fil for pinout in mach so iam guesing those right to.
anyone have had this problem ??
best regards Brian
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.20 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
