Hello
Guest
it is
April 26, 2024, 06:46:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Windows can't start up with pokeys56u plugged in
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Windows can't start up with pokeys56u plugged in (Read 3291 times)
attila0216
24
on:
April 10, 2016, 12:48:55 PM »
Good eveving to All,
I have a wierd thing with my pokeys 56u. When pokeys plugged in via usb port and i try to turn on PC windows can't start. If i unplug it, windows starts up with no problem. However ones is windows loaded and i plug in pokeys it works with no problem.
What can be the problem?
Logged
GerdS
42
Re: Windows can't start up with pokeys56u plugged in
Reply #1 on:
April 10, 2016, 03:38:18 PM »
Did you try to play with the Bios startup Parameters.
Maybe the Bios means it is a bootable Device.
Logged
attila0216
24
Reply #2 on:
April 13, 2016, 03:56:54 PM »
Yes, thank you!!!,BUT I have tried i disabled usb boot up only my ssd enabled but still i am getting this error. But only pokeys can cause this issue, cause whenever i plug out prior to pc start, no errorrs. Any other idea?
Logged
NeoTO
504
Reply #3 on:
April 14, 2016, 12:10:46 AM »
Some BIOS use highly simplified USB stack that apparently isn't able to process (perfectly legit by USB standards) USB device descriptor and hangs.
We implemented the 'delayed start' option for such cases - set the amount of time the PoKeys device will wait before registering to the USB host. The setting is available in PoKeys application under Settings, start-up configuration.
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
jetlag
1
Reply #4 on:
December 08, 2016, 07:06:40 PM »
I have the same problem but cannot find this "delayed start" option in the menu of Pokeys config v3.1.4.
All I see is "Enable fast USB interface" and some startup options re: digital outputs.
I believe 3.1.4 is the latest available for 56U because that's what comes up if I try to update.
Can somebody help?
Logged
NeoTO
504
Reply #5 on:
February 25, 2017, 01:40:29 AM »
Update the software and firmware to the latest version and you will have that option. Latest version for 56 series is 3.1.68.
Logged
www.poscope.com
Print
Pages:
1
Go Up
« previous
next »
